unconfigure mld
unconfigure mld
Description
Resets all MLD settings to their default values and clears the MLD group table.
Description
Default
N/A.
Usage Guidelines
None.
The following command resets all MLD settings to their default values and clears the MLD group table:
unconfigure mld
Platform Availability
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
